- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108
@Netduma-Fraser wrote:
@Toadie0909Each platform running the beta or 3.0 will have its own bugs some are exclusive to the platform and some not.
@mreich1978I’ve chased so hoping by end of day.
@rbarba23do devices get an IPv6 address in Device Manager at all? Public IP is still showing IPv4?
@CoronalAuroraglad to here it is working now. Okay thanks, I’m assuming devices aren’t disconnecting or anything while this is occurring?
@Retired_Memberokay interesting, and I assume you’ve tried different cables/ports to rule those out? Okay so no IPv6 shown for devices in Device Manager and public IP still IPv4?
@Anton774that is brilliant to hear! I will request a Blu Ray option and lock again.
@Netduma-Fraser no I don't think devices are actually disconnecting, my son is playing fortnite atm and I have seen the PC go offline/online a few times whilst he was playing in a public match.
On a positive note the geo location and QOS detection seem to be working flawlessly with the PC set to be an XBOX in Device manager, and Console in GL & QOS. That is something I've not seen for a long time and is really good if it keeps working. Its still a little annoying that you have to set the PC as a console. It would also be much better for me to be able to disable All Dumaos classified games and add the xbox with Apex and Fortnite manually, the same for PC too, so that the Congestion control only kicks in during those games. Means my limited bandwidth isn't throttled for no reason when playing single player games. But I'm happy enough with the way its working for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sergio2020 O que nunca foi resolvido especificamente? Todas as plataformas terão bugs, é assim que o software é. O R2 é otimizado para DumaOS, portanto, é provável que seja mais estável.
@minino I get that as well without the Geo-Filter so I think that is just the game.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser
Hello,
OK so I'm seeing a fair bit of the Xbox Live traffic not being picked up and prioritised to the Series X, it's just treated as normal traffic,thus increasing pings etc, as soon as I tinker with it, and force the QoS to prioritise the device it works, but I have to do this every session and every game to get it to detect, it seems to suffer from short term memory loss.
With regards to the IPv6 DNS, it's changing the defaults in the IPv6 setup screen. I use a Draytek Vigor 130 in bridge mode to connect to the internet, so the XR500 handles everything regarding the connection settings. I've set them in the ASUS router and they're picked up and assigned and you can see that in every device connected to the changed DNS, with the XR500 each device reports my ISP standard IPv6 DNS servers, even though the assigned ones in DumaOS are Cloudflare.
With Android 10 and 11 they started the devices assigning a random MAC address to every wifi network you join, you can turn it off but it then starts to cause issues on that side, but each time the phone connects to the router, it gets assigned the same IP address, but then it appears the XR500 checks the MAC address of the device to the static assigned IP address and notices a conflict and then blocks the device, thus showing as a disconnect, device name and IP address stay the same, but it doesn't like the random MAC side of Android. Well that's the only logical explanation I can come down too with the amount of testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmm, looks like IPv6 DNS servers aren't working properly in this build. Had no trouble getting 1.1.1.1/help to detect the Cloudflare DNS servers on 103, but now they won't at all in 108. All ipv6 tests fail as well. Did a factory reset prior to upgrading, upgraded, then did another factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting. Was able to use QoS and ipv6 in the last beta. That's fine I guess for now, at least it's working with QoS disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
is a factory reset required?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zmon is it the same as Bryer? It applies in Settings but doesn’t actually work?
@CoronalAurora Okay sorry to hear that, we’ll see if we can reproduce that.
@iielmesswavy not required no but if you have any issues please do a factory reset to see if it solves them before reporting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Geo Filter is not working properly.
I added my computer to traffic prioritization as a games console.
I then added my computer to the geo filter. I selected Call of Duty PC I get a message that states:
"Device Added SuccessfullyTLE - Call of Duty-PC
Your device has been added with Filtering Mode disabled. You will still be able to ping and monitor servers in real-time. Filtering Mode is not currently supported for this game."
I cannot turn filtering on!
So I added my computer to Call of Duty...
Geo Filter no longer works
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser Yes, you can apply IPv6 in settings, but it doesn't actually work. bryer84's solution of disabling QoS fixes it though oddly enough. I know he mentioned he had issues with IPv6 and QoS in build 103 after an hour, but mine stayed on and worked fine. Unfortunately, again, I had to disable QoS completely to get IPv6 to work in the 108 build.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setup
XR500 connected to Netgear ax12 ( DMZ set up. Worked with @Netduma-Fraser on this.
Issues -
1. Benchmark not showing the speed as show during set up. Attachment are posted as well.
2. In geo-filter- when adding device you have the option to do recommended or do manual. Now, when do recommend it doesn't show many games or doesn't concur with console. For example, Its an xbox and its showing me games for PC.
3. IPV6 not working correctly, I don't know if its due my set up or if it the router.
@Netduma-Fraser please reply as soon as you can. No rush
P.S. there are no issues with disconnectivity or anything else really.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zmon thank you very much for clarifying that, I will pass it on.
@iielmesswavy Benchmark isn’t reporting full speeds at the moment so you can ignore that. When adding to the Geo-Filter use the manual option and it will work. We’ll look at the IPv6 issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Thank you @Netduma-Fraser
- Mark as New
- Bookmark
- Subscribe
- Permalink
After seeing some others have some success I upgraded last night. No factory reset YET. Observations so far:
- Network speed previously set on QoS didn't carry over to the new areas where it is referenced. QoS looks fine but when opening network speeds from top bar it shows 1000mbps up and down. Despite changing this it is not reflected on the connection benchmark. No dashed line.
- Devices that are in included in traffic prioritisation do not respond to bandwidth limits. Not sure if this is intentional but havent seen this behaviour in previous builds.
- As already mentioned device manager is still a mess in terms of online and offline devices. Showing devices that are live on the network is very helpful for network monitoring and admin. It really should not rely on them accessing the internet. I have network switches, WAP and NAS that never access the net so they are constantly offline. Every other router I have ever owned is capable of showing a list of 'connected' devices. If you think seeing devices actively connected to the internet is helpful then have 2 screens. Online devices&connected devices. Even if the 'connected devices' just runs an arping request when its open that would be better than seeing devices jumping about all the time.
- Connection benchmark, not saving test results. Also already mentioned that the QoS limits are not applied during under load test resulting in poor results every time. Rapp taking too long warning occurs during the test.
Looks like you are getting there and hopefully you are in a position to just roll out Rapp updates for fixes as opposed to waiting months for new full firmware.
p.s. love the new device settings popup as opposed to the slide in side bar. I saw this on my mates R2 and happy to see it on XR500. Feels loads better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser Router just locked up completely again. No games being played no QOS active as far as I am aware. 2nd time in less than 24 hours. Symptoms are that everything seems to be connected to wifi but no internet and the web interface for the xr500 was just unresponsive, pages just with spinning circle so can't even get any logs or see whats going on. Theres 5 people in the house so I do have a busy network with TV's, Sky, smart home devices and a lot of phones and tablets...39 in all about 25-30 showing online at any one time. Really fed up with this. I got cut off from an important work call this time. I am going to try .66 for a while and if it keeps happening then I can't continue with this router any longer. What's my recourse with Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the new version it is very difficult for you to log into origin.
on the other hand I wanted to ask if it is better in pc normal geofilter or put it as a console game, I currently have apex in spectating mode pc mode and traffic prioritization apex legend (nothing console game) the qos 68-45
When I start apex it always gives me lost packages, put the values that I put, any solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CoronalAurora wrote:@Netduma-Fraser Router just locked up completely again. No games being played no QOS active as far as I am aware. 2nd time in less than 24 hours. Symptoms are that everything seems to be connected to wifi but no internet and the web interface for the xr500 was just unresponsive, pages just with spinning circle so can't even get any logs or see whats going on. Theres 5 people in the house so I do have a busy network with TV's, Sky, smart home devices and a lot of phones and tablets...39 in all about 25-30 showing online at any one time. Really fed up with this. I got cut off from an important work call this time. I am going to try .66 for a while and if it keeps happening then I can't continue with this router any longer. What's my recourse with Netgear?
@CoronalAuroraI suggest you keep a browser tab open on routerlogin.net/debug.html. I had that same issue with the last firmware. The router will go to 100% CPU and just crash. It was happening multiple times per day for me. Sounds like they didn't fix that issue, well since there are no release notes, we don't know what they fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Xavg wrote:
Ipv6 (Orange) is not working because no dns is returned by the xr500. Setting up manually and it's working. Also when the ipv6 is turned on, the block services is working only with the ipv4.
Which Block Services feature are you talking about? The one in the settings section or the one in Traffic Controller?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Killerelite06 wrote:
4.Still have devices that show offline
Can you still access the internet on these devices that appear offline? When clicked, do they still have an IP address? Can they be deleted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
