- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser hello yesterday I installed new software, the installation went smoothly, re-installation to the factory settings:
-upnp doesn't show anything
-qos flower doesn't save percentage, worked for the fifth time
-vpn all the time dns leaks
-I had one message all qos functions disabled, go to qos section and enable
-ipv6 prefix is still appended to devices (ipv6 disabled)
-ping hitmap shows only one server in europe cod warzone
-device manager working fine
I will check out more options by the end of the week
- Mark as New
- Bookmark
- Subscribe
- Permalink
shows only one server in warzone in eu.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RE: Hybrid VPN with ExpressVPN
Error recently started popping up (Uncaught TypeError:Cannot read property 'type' of undefined) on .104 updated to .108 this morning and still occuring.Unable to load devices to vpn.
Did Factory reset and reboot also cleared all browsers
Config files are correct and Connects to ExpressVpn server without problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
"@Xavg Will report the Ping Under Load issue. Block services are you referring to the feature in Settings or Traffic Controller? Can you provide a screenshot regarding being unable to change DNS with Orange DHCP please?"
Hello 🙂
It's the blocking feature in Settings and not in the Traffic Controller. If the Traffic Controller do a better job maybe it will be good to remove this on the settings side or a backlink to the Traffic controller... ? I will try with the Traffic Controller with this version.
For the Orange DHCP, the capture is linked to this post.
For the IPV6, the conflict is when the QOS is enabled for sure.
Thanks for following up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CoronalAurora really sorry to hear that. It is probably the persistent DHCP issue. Thank you for the information though, that really does help. In terms of your recourse that really depends on where you purchased etc and warranty.
@minino Could you expand please on what is difficult about logging into Origin on this update please? I personally would recommend to treat the PC as a console, so PlayStation device type in Device Manager, add to the Geo-Filter with the manual option and select Games Console on Traffic Prioritization. Do you get packet loss the whole way through the game? – If you enable the newly implemented network stats from settings you can see this when playing.
@rbarba23 thanks for clarifying.
@Raf1212 If you do a connection test on a console for example can you see any ports appear? How did you adjust the percentage exactly? Were you switching between applications/devices? Aware of VPN, we’ll sort that out. I don’t follow what you mean regarding QoS. So devices are getting IPv6 addresses without IPv6 being enabled? We’re working on updating heatmap for that, it will be done via the cloud. Thanks for the feedback so far.
@Anton774 we’ll be updating heatmap for those games, it will be done via the cloud so nothing needed on your end.
@minino Could you expand on those issues please? Are wired/wireless devices losing connection? The router is rebooting on its own? What web browser/device are you using to access the interface?
@Falcon1255 Could you provide a screenshot of this error/where devices can’t load please?
@Xavg understood, that is for HTTP sites and so as most of the internet now uses HTTPS it probably won’t work all the time. Yes Traffic Controller should be much better, thanks for that suggestion. Thanks for the screenshot, so it won’t let you type at all into the DNS boxes? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser thank you for your reply. I was using chrome but did not clear cache. After a router reboot the connection benchmark seems sorted. Dashed line appearing as normal and previous tests now appear to be saved.
I intend to do a factory reset at the weekend when I have the strength to go through the process.
One new issue, xbox live parties appear to be getting randomly blocked by geofilter. Something is identifying as in the US and it boots me from an already established party. My friend with an R2 is having the same problem. Is this something you have seen?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@quadrophenic That's great to hear! If you notice something blocked on the map when you try to join a friend/chat then add it to your allow list, does it work then? We've only seen that on a different platform currently not those 2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser I was watching my geo filter and a 'player' randomly appeared in the US so i allowed it but still couldnt rejoin until i enabled spectate mode. all servers were shown inside the filter radius. My friend with R2 couldnt reconnect at all. I recommended the R2 to him so I am getting some serious abuse
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser I only played cod brewed, there is an open port 3074 in the game, and with qos - I got the message qos was turned off, I had to turn on
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser "so it won’t let you type at all into the DNS boxes?"
I can't do anything . The "Get Automatically from isp" seems to be mandatory 😕
For the "Traffic Controller" i can confirm this is much better ! The old block service can be removed maybe...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Raf1212 Had you turned it off on the previous firmware?
@Xavg what browser/device are you using as I saw another user using their mobile browser and the option was there to change it. Great to hear about Traffic Controller.
@minino you can find the Apex ports here: https://portforward.com/apex-legends/
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
last week I turned off for a while, then I turned it on and it worked,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
flashed on screen loading Hybrid VPN Rapp
I did a 30/30/30 reset this morning that cleared the error, however I have not loaded the open config.file from exspress vpn yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HybridVPN connects fine, but when I check my public IP on the device selected, it shows my ISP's IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser Following another 2 crashes yesterday I decided to try and send the router back to where I bought it. It's unlikely I'll be getting my money back from Curry's as I got the router in May so looks like I'm stuck with it. To that end, I have tried one more thing before downgrading to .66. I've put a another switch in between my wired devices and the xr500 (Now have 2 switches plugged into port 1 and port 2 on the xr500, about 8 devices in total goig through these) and also another switch between the xr500 and my modem off the WAN port. I read about similar issues going back to 2018 and that it could be instant on set on the xbox or some other wake on lan sleep power type problem with wired devices. I've also read a few threads that changing the modem can help but I can't do that at the moment. Btw my xbox has always been in power saving mode anyway and auto game updates switched off so don't think thats this issue. One thing I have noticed is that my modem only has a 10/100 interface and also my main Sky box is only 10/100 also. So I've put the switches in to take the hit on any negotiation or power saving problems. So far no crashes but its only been 12 hours and overnight when its not being used much. I'll let you know how it goes but I must voice my displeasure that a 2 year old problem hasn't been addressed fully, if that is indeed what is ocurring. Maybe it's a weakness in the LAN & WAN ports on the xr500 and is down to hardware, in which case maybe can't be fixed which is no consolation whatsoever.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser not now not working, any suggestion for upnp,one more thing, when I add an NTP server in the settings, change the time automatically to summer time, after a few hours it returns to the original settings, returns the saved setting
- Mark as New
- Bookmark
- Subscribe
- Permalink
