× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
New Firmware v2.3.2.108 (XR500)
Delx
Apprentice
Re: New Firmware v2.3.2.108 (XR500)
part 2
Message 326 of 769
Netduma-Fraser
NetDuma Partner
@Delx thank you but could you get the whole debug log, which consists of the WAN/LAN captures as well please and just upload the whole thing as a zip and PM to Tim.
Message 327 of 769
Delx
Apprentice
ok can you delete my previous post with attachements?
Message 328 of 769
Retired_Member
Not applicable
I use geofilter with filtering mode when playing warzone, but does anybody know how to disable hosting through other players in the lobby? Marked as peers? I only want to get connected to dedicated servers.
Message 329 of 769
Netduma-Fraser
NetDuma Partner
@Delx I don't have the permissions to do that unfortunately, you may be able to do so.
@Retired_Member its probably that the peers are misclassified as servers, even if they aren't it's not possible to do that and it would transition to a server when actually in the game playing.
Message 330 of 769
Where can I find the beta of DumaOS 3.0 for XR500, I can't find it, I can't find where to download it, or how would it be?
Message 331 of 769
Netduma-Fraser
NetDuma Partner
@Gilbertdelmao it is on the first post of this topic
Message 332 of 769
Xolhid
Apprentice
@Gilbertdelmao
Man Surprised
 That is like trying to find your keys when they are in your pocket.
Message 333 of 769
kxndal
Guide
Betreff: New Firmware v2.3.2.108 (XR500)
very quiet here .. when will we get a new update?
Message 334 of 769
Xolhid
Apprentice
When there is something to update.
Message 335 of 769
Iamcity
Tutor
THIS LINK THAT YOU SENT IS JUST A PDF FILE. WHATS THE PURPOSE OF THAT.
Model: XR500|Nighthawk Pro Gaming Router
Message 336 of 769
Iamcity
Tutor
HOW CAN I GET THE MOST RECENT FIRMWARE UPDATE FOR MY XR500?
Message 337 of 769
Netduma-Fraser
NetDuma Partner
We're working on a new update at the moment but I don't have a timeframe for that yet.
@Iamcity it is a .img file, not a PDF file. You do not open the file on the PC, you upload it to the router by going to the Interface, Settings > Administration > Firmware Update
Message 338 of 769
Iamcity
Tutor
i've done that and it says upload an correct file. it clearly says Img. file.
Message 339 of 769
Xolhid
Apprentice
@Netduma-Fraser
Can you share any details on the changes we can expect with the next update?
Message 340 of 769
CoronalAurora
Apprentice
Just thought I'd let you all know how I ovecame every problem with my XR500.
I put it in AP mode and bought an Ubiquity EdgeRouter 4 to do all the routing. No crashes, no hangups, can always get to the web gui, no random loss of internet, QOS using smartqueue on the ER4 works really well and I don't have to limit my bandwidth to 16% to get an A+ on DSL reports in fact I have 95% of my bandwidth using it and its better , IPV6 works. Its a real shame the XR can't be a router and an AP and do QOS and IPV6 at the same time, a shame mainly for my bank account. To be honest I would have bought an Ubiquity access point too if I'd not spent so much on the XR500. Which brings me to its plus points. The wifi signal is pretty good...thats it.
So good luck everyone, you are going to need it.
Message 341 of 769
Netduma-Fraser
NetDuma Partner
@Iamcity can you provide a screenshot of the Firmware update page with the file you've upload please?
@Xolhid it will be mainly fixes but I don't have specifics currently.
Message 342 of 769
Not sure if I'm the only one, but the ping heatmap doesn't work for me. Is there a fix for this?
@Netduma-Fraser
Message 343 of 769
Netduma-Liam
NetDuma Partner
What issue are you seeing with it? Is there any particular error message or is this occuring with any particular games?
Message 344 of 769
Conanti
Guide
@Netduma-Fraser Been testing this latest build for the past month and i am very happy to report my results on previous bugs/ issues discussed.
1. UPNP port table not showing and sometimes not automatically opening - Fully operational showing everything and opening ports correctly.
2. QOS not limitig bandwidth correctly and poor bufferbloat - Now limiting, also improved bufferbloat spikes from 72 ms to 9ms with 90% up/down. Repeatable results, incridibly impressed.
3. QOS not optimising for certain games. Tested Guild wars 2, World of Warcraft and League of Legends all working but GW2. Created a manual prioritsation for port 6112 and now working flawlessly. If the backend team could code port 6112 for gw1/2 into duma os classified default should now work by default saving anybody else having to create a manual port. (gw1/2 both use 6112 i believe)
4. Random router crashes only resolveable with hard reboot once often more per day - 4 weeks no crashes, hang ups and also incredibly stable when speed and ping tested in games - totally resolved.
This has fixed all my issues an im incredibly impressed and greatful for the work being done. I know others are having issues still and i can only encourage patience look at all the issues resolved i was experiencing.
I factory reset to last stable release (non beta). before update then factory reset again then updated to latest beta and working flawlessly. Havent tested other features like ping map because i dont really use. might test in future but kind of useless for australians
Message 345 of 769
shaolin95
Guide
This is my last post here...I finally have my router working perfectly! No drops, no restarts..and the worst spost in my house where I was barely getting 30Mb downloads now I get over 250Mb...the solution was simple...I got the Asus AX11000 and sold the XR500. I held as long as I could with the xr500 but at some point you just need to realize, things will never get better at this rate.
Good luck to all of you.
Message 346 of 769
Netduma-Fraser
NetDuma Partner
@Conanti thank you so much for the feedback, really glad to hear you're having a good experience and that it has resolved your issues.
Message 347 of 769
iielmesswavy
Apprentice
@Fraser is it okay to use to NAT on OPEN?
Message 348 of 769
Netduma-Fraser
NetDuma Partner
@iielmesswavy yes you can do that, I use that option myself.
Message 349 of 769
Delx
Apprentice
I will be taking this solution very soon, mine messes up when you turn 5ghz on.!
Message 350 of 769
Top Contributors
Announcements
Orbi WiFi 7
