- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108 (XR500)
when i hit Erase in backup settings,not all settings go back to the original settings.
And in dumaos ver 3.0 114 build upnp does not show the ports used by playstation 5 and in call of duty have strict nat, but on the original version 2.3.2.66 upnp show ports and i have open nat , also in 3.0 114 when i set dmz server on my ps5 yes i have open nat but also lost packet where i never had
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting, I'd advise performing a full factory reset after upgrading, this ensures you clear out any low-level code that could be having an effect. Please try this and let me know how you get on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Liam I do not know if it will help but I restored the factory settings, and I still had the same settings in the allocation of bandwidth, and only here, another dish was deleted
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello all, have been updating the firmware accordingly just like everyine else and am having the same issues somewhat. My traffic prioritization does not load at all, the QOS will load along with bandwith allocation but no traffic prioritization to select devices. Also, when i load the dumaos app i noticed the high priority traffic light would go in and out signaling if high priority traffic was detected. Has anyones dealt with these issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you just upgrade to 114? Did you perform a factory reset after the upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, how did you perform the reset, was it through the GUI or using the physical pin on the back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you getting an error when you try to load QoS? If so, what is it?
Is your mobile device priotised at all in QoS? It may just be detecting that and determining it as high priority traffic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Martdog23 wrote:hello all, have been updating the firmware accordingly just like everyine else and am having the same issues somewhat. My traffic prioritization does not load at all, the QOS will load along with bandwith allocation but no traffic prioritization to select devices. Also, when i load the dumaos app i noticed the high priority traffic light would go in and out signaling if high priority traffic was detected. Has anyones dealt with these issues?
There seems to be a trend where after loading .114 firmware, things in the QoS is broken after .114 first boots on install. The fix seems like disabling QoS, rebooting, then enabling fixes the problem. Just comparing notes to what others are seeing, including myself who saw similar issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the error message i receive is 'device not found'
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have restored the factory settings again and confirm that I do not remove devices or prioritization added manually to devices, and with the flower of prioritization, the browser data has been deleted earlier
first reset gui, and the second pin on the back, nothing helps,
- Mark as New
- Bookmark
- Subscribe
- Permalink
same message as all users the device was not found
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser @Netduma-Liam I forgot to add that devices that were removed are no longer displayed as those from before restoring factory settings, most of them were displayed as playstation
- Mark as New
- Bookmark
- Subscribe
- Permalink
any configuration tips to improve hit detection in apex legends pc? I have 70-70 qos with 600mb, apex legends high priority traffic, geofilter on london server. upnp disabled because it doesn't work right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so it's maintaining some configuration even after a factory reset? Thanks for letting us know, we're looking into this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
What results do you get if you perform a connection benchmark? This will help us check if QoS is working correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the connection benchmark has not worked properly for me since i downloaded the beta firmware for xr500. I have a r2 as well and its benchmark takes me all the way down to 1% on recommended qos. xfinity modem/router combo i put in bridge mode for router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
@ep2015Let us know if it happens again and what is happening on the network at the time please.
@crmontoy1https://ntgr-my.sharepoint.com/:u:/g/personal/tichang_netgear_com/Ecek7S3fUjZHmGi11s60rNQB1eZUv5HHh-...
Currently noticing 100% spikes again for the last several days. My logs are showing a lot of DoS Attack and "Lan access from remote" entries.
My speeds seem normal and it doesn't seem to be impacting much, but I did get a message from my Synology NAS sayng that an outside IP address is now blocked for making too many unsuccessful attempts to access it.
I'm slightly more concerened now that the NAS is also sending red flags
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ep2015 What is the IP shown in the log entries?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ep2015What is the IP shown in the log entries?
All kinds:
145.239.205.207
34.78.227.165
67.248.212.198
188.166.87.22
72.21.81.200
46.4.17.145
96.114.14.140
52.205.139.14
130.211.16.53
It just keeps going. Some of the DoS Attacks will usually have the same IP listed for five or six entries, but many will have different ones per entry. The "Lan access from remote" seem to always be different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They all seem fine, nothing suspicious, just same game servers and connections you've likely made by web browsing.
Does the fact that my CPU locks at 100% when these events show up in the log warrant any concern?
