× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
New Firmware v2.3.2.120 (XR450)
Netduma_Alex
NetDuma Partner
Hi all,
Thanks for your patience, we’ve got a new firmware for you to test.
Highlights of this update:
  • Big improvements to IPv6 compatibility
  • Improvements to general stability
  • System-wide GUI improvements
  • Updates to game and device detection
  • Fixed DHCP renewal causing internet to drop
I would highly recommend you do a factory reset after upgrading for the freshest installation.
Firmware: https://www.dropbox.com/s/p0ohpkiz45dpt2g/XR450-V2.3.2.120.zip?dl=0
Message 1 of 126
Guru
Re: New Firmware v2.3.2.120 (XR450)
Thank you. Will get it loaded and start testing. Smiley Wink
Message 2 of 126
dewayne221
Tutor
I dont think congestion control is working with ipv6 on
Message 3 of 126
Netduma-Liam
NetDuma Partner
How have you come across this? What differences are you seeing that suggests IPv6 is causing an issue with QoS?
Message 4 of 126
dewayne221
Tutor
I was testing ping with cmd and it shoots up to like 300 while under load with ipv6 on with it off it still shoots up but not as bad like 80 some
Message 5 of 126
Netduma-Fraser
NetDuma Partner
What QoS settings were you using while doing this test?
Message 6 of 126
dewayne221
Tutor
Qos was on always i even put the sliders at like 50 percent also the speed test on the router give me A+ on the first 2 and a D on the  ping under load test
Message 7 of 126
Netduma-Fraser
NetDuma Partner
Did you do a factory reset after you upgraded the firmware?
Message 8 of 126
dewayne221
Tutor
yes
Message 9 of 126
Netduma-Liam
NetDuma Partner
How did you perform the factory reset, through the interface or via the pin on the back of the router?
Message 10 of 126
dewayne221
Tutor
Both i did interface first on old build and pin on new build
Message 11 of 126
Netduma-Fraser
NetDuma Partner
Could you try factory resetting from routerlogin.net/adv_index.htm please as I'm not sure the other methods are resetting correctly, then try please.
Message 12 of 126
Retired_Member
Not applicable
what are the new features on this build id like to know
Model: XR500|Nighthawk Pro Gaming Router
Message 13 of 126
Netduma-Fraser
NetDuma Partner
@Retired_Member there are no new features over the other beta builds, just what is mentioned on the first post.
Message 14 of 126
Retired_Member
Not applicable
i found an issue with the xr450 beta update it tries to connect but it immediately disconnects the wifi on some devices so i had to downgrade to the non beta update
Message 15 of 126
Netduma-Fraser
NetDuma Partner
Did you do a factory reset after upgrading? If not I would highly suggest doing so as it prevents issues carrying over
Message 16 of 126
Retired_Member
Not applicable
Ohh ok I keep forgetting but the last update I. Never had that issue
Message 17 of 126
Netduma-Fraser
NetDuma Partner
It won't always happen but depending on what gets changed between the versions, old level code from a previous version can cause issues. Re-upgrade then factory reset and see if you get the same issue please.
Message 18 of 126
dewayne221
Tutor
I tried that same issue
Message 19 of 126
Retired_Member
Not applicable
It worked over here
Message 20 of 126
Netduma-Fraser
NetDuma Partner
Okay thank you both, this is something we'll really need to try and reproduce ourselves, will get back to you if I get a good workaround.
Message 21 of 126
dewayne221
Tutor
i meant i was still having the ping under load issue still
Message 22 of 126
Netduma-Fraser
NetDuma Partner
@dewayne221 oh I see, did the factory reset using that page wipe everything successfully for you then?
Message 23 of 126
dewayne221
Tutor
@dewayne221oh I see, did the factory reset using that page wipe everything successfully for you then?
mostly i think my internet speeds stayed
Message 24 of 126
Netduma-Liam
NetDuma Partner
Where did you see that they remained the same? Did you not set this when going through the initial setup?
Message 25 of 126
Top Contributors
Discussion stats
  • 125 replies
  • 14365 views
  • 17 kudos
  • 12 in conversation
Announcements
Orbi 770 Series
