- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.120 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.120 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have allways enabled and its when am using connection benchmark
i have the xr500 to a openreach modemuseing ppope
- Mark as New
- Bookmark
- Subscribe
- Permalink
and am on i wierd connection on laptop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i no this but when am moving the sliders for a better connection they dont do anything to my speed or the results ther all the same
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
do you need internet explore for it to work? I only have google chrome
- Mark as New
- Bookmark
- Subscribe
- Permalink
says file is corrupt after I download it and try to open.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You won't be able to open the file, you'll need to upload it to the XR500 to upgrade the firmware.
To do this, access the DumaOS interface via routerlogin.net and do the following:
- Select Settings > Administration > Firmware Update.
- Click the Browse button.
- Find and select the saved firmware file on your computer.
- Click the Upload button.
After you've done this please factory reset the router to ensure you're starting fresh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what two or thee vpn are the best to use with m xr500 and dumaos?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also which file do I download because there are two. the .img or the .img.md5
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
i was hesitant to install the beta firmware but i've been dealing with a bunch of crashes (that i was blaming on my ISP as most of the time the internet just dropped and i could talk to the router so i thought it had to be the modem/isp) and recently i noticed my 300/30 connection topped out at 150-180/20 so i was getting kinda fed up with the XR500's shenanigans (though at the time i thought my ISP was screwing me over).
decided to install this firmware...best thing i could have done, was planning on trying it assuming it wouldn't change much and then have a angry and unpleasant phone call with the ISP...which was thankfully avoided >.>.
no more crashes, 300/30 connection speed.
it was crashing 1-6 times a day so i figured things can only get better at this point and they did.
had another netgear router like 8 or 10 years ago that probably didn't crash once in those years so i just thought it's impossible that it could be the fancy new router >.>
- Mark as New
- Bookmark
- Subscribe
- Permalink
This latest DumaOS Firmware has many issues . It seems 1 major issue is that the Wifi clients lose internet access at times even though they seem to be connected. When I login to Router , I see that the device Manager tab is hung and takes forever to launch. I end up rebooting the router manually and everything is working again.
Is there a solituion to this ? We have been pateiently waiting for over 3 years for a stablized version of this OS. What is the most reliable and "stable" firmware version for this router.?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
When are you seeing the Device Manager take awhile to load, straight after a reboot or when its been on for awhile? What wireless devices disconnect? Are you using Smart Connect? This is the most stable in my opinion, did you factory reset after upgrading?
Device Manager just hangs and I need to reboot router for wifi to actually work again. All wifi devices seem to lose access to internet but show connected.
I am not using Smart connect as I have multiple SSID's. Yes I did a factory reset multiple times after updating to latest dumaos.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the System Information page on the Rapp panel menu, change retries to 5. On WiFi, change the mode on 5GHz down from the 4000 range to the one below, then reboot from the interface, wait 2 minutes before connecting/accessing and see if its any better please
Hi , Thanks for info - will try, what Wifi setting are you referring to 4000 - ????
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go to Settings > Wireless Setup then for 5GHz change the mode, it will be set to 4800 Mbps, change this to 2400 Mbps and then apply. Make sure you've done the retries, then reboot from the interface
Hi
My Settings for 5GHZ on xr500 are 1733, 800 and 347? where do yo get 4800???
- Mark as New
- Bookmark
- Subscribe
- Permalink
