- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.120 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.120 (XR500)
@crmontoy1 can you also follow the steps from Tim please so we can try to narrow down the disconnect issues? I've let the team know about Fifa for heatmap and they will update it - please try it again in a few days. I generally don't recommend to use Ping Assist but if you want to use it I would suggest 40ms.
@Dumauser3348493 what speeds do you usually get and what are you getting now?
@BIG_DOG great to hear that BD, thanks for the feedback!
- Mark as New
- Bookmark
- Subscribe
- Permalink
20/up
Currently getting 120/down over wifi. Disabling qos didn't really help.
I'm gonna try a factory reset from the button and this time I won't enable ipv6 and see if it's corrects the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well since my downgrade and update etc etc, I am still having disconnects but only once a day now. Will start capturing logs again to see if a new log will help identify it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would have been nice to do all that if the router was accessable. As I already explained to your coworker when the internet dropped out it was as if the router crashed. It was unresponsive to any way I tried to access it. I don't know how you expect me to gather logs for you when it's not responding at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Xolhid,
Okay I see. So only way to recover the device is to reboot the XR500?
Do you have same issue in previous beta version of V2.3.2.114? And did it happen every time within 24 hours?
Can you still help us to collect the debug log after the reboot, we still can look into it and see if any useful information.
BTW, would you also please provide the serial number of XR500, which is in a label that attached in the bottom.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would you please help to provide the debug logs?
0. Make sure you've reproduced the issue.
- Open the web browser via a PC, go tohttp://routerlogin.com/debug.htm
- Click “Enable LAN/WAN Packet Capture”
- Click “Start capture”, and wait for 30 seconds.
- Click “Save Debug log”.
- Send the log to us.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, thank you. Let us know if you can capture a log with anything useful!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you give me the steps!! Ill be able to send the logs to you
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TimChang wrote:Would you please help to provide the debug logs?
I already reset it now so next time IPv6 fails I'll do that.
This still doesnt explain why IPv6 isnt working natively though. Why is the router only working using IPv6to4 and not authenticating with Sky via IPv6 when its avaliable and works fine with my Sky hub on the same line?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yet another problem with IPv6. When downloading on Steam my speed was fluctuating betweem 800kbps & 2.5MB/s. As soon as I disabled IPv6 on my NIC download shot straight up to the 9MB/s it should be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed tests show the correct speeds it just seems to be downloads from sites like Steam, Google play etc
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I've reset through the hard button. Rebooted. But the download speeds over wifi are still not full speed. Speedtest.net show 40-80mbps over wifi. Should be 400mbps. Lan connection speeds are fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speeds are you seeing in Connection Benchmark? Do they appear to be full speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe stupid question but can anyone point me in the direction of how to install these?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@stridahtv download the file, then go to the router interface - type routerlogin.net into your browser, go to Settings > Administration > Firmware Update and upload the file there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ping under load was unusually high. +40ms dl
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something is up with 2.4ghz
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
