- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.120 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.120 (XR500)
@Dumauser3348493 make a custom rule on Traffic Prioritization for the PC, src 1-65535 dst 1-65535 Normal, Apply to WAN then do a speed test please and see what you get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did that bruv,still zero server data on my Geo-Filter...anything else..?,getting kinda frustrated now, no offence but can you guys get the XR500 to a stable build to run DumaOS 3.0 without issues..? How many years left of this Beta? Ive been very patient for months now and well a fuse blew with this upgrade today,Help me understand please bro,what is going on..?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My phone's battery saver 🙈
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Dumauser3348493 haha no worries, happens to the best of us, thanks for the update on what it was!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser
Nothing comes up bruv,Geo-Filter is empty like my pockets,my console is connected directly to the router via cat8 gold plated 1 GB cable,anyway,.. I went back to .114 DumaOs 3.0 and everything works fine for me,The Geo-Filter is a Christmas Tree again,woohoo. I do think that whenever yall drop an update ill wait a week to see others feedback to determine whether i should update or not,I want 3.0 but these constant issues can get to the best of us.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunaltely, we don't have this design. You should have wifi and GUI management credential pretection. It should not easily be accessed by others.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection keeps dropping even after the newest update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I had reset the router after .120 update...Thanks for the .104 link and I have now downgraded to 104 and hope not to see internet drops cos I never had Internet drops issue with .104 before when it was released.
- Mark as New
- Bookmark
- Subscribe
- Permalink
--DELETED--
Found the problem 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@PEJMAN there isn't a way to do that currently, I'm not sure if it's something that will be implemented but maybe @TimChang can take a look at that possibility?
yes please force him to make changes and i'm very grateful. i think it is very important option to implement to the OS, and i know other company´s already have this option in software level. please add this option in futur!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Nareshak keep us posted!
@PEJMAN Tim has said this won't be possible above: "Unfortunaltely, we don't have this design. You should have wifi and GUI management credential pretection. It should not easily be accessed by others."
- Mark as New
- Bookmark
- Subscribe
- Permalink
As mentionned in several posts, the disconnection issue is still there.
After a bit more of a week of uptime (it's always around 7 days and a few hours since the first beta), wifi internet is dropped (you are still connected to the wifi), then lan internet is dropped, then ultimately you can't reach the router (ping comes back with error).
Manually turning the router off then on solves the issue for a week.
I'm using only IPv4.
At this stage instead of trying to fix an issue that is plaguing this router for a long time now, may I suggest a planned reboot feature implemented please.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@spdsk8race wrote:
For anyone experiencing the router rebooting or dropping internet, do you have traffic meter enabled?
Yes I have. Do you think it's what overflow the memory of the router or something ?
@Netduma-Fraser wrote:
@mathmath51@Code_killif you're able to get the log information as per the instructions here and PM them to @TimChang that would be really helpful for NG to be able to resolve the issue https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/m-p/2...
The issue is that you don't have much time between loss of internet and router unreachable 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reset your counter, hit apply, then turn the counter off (uncheck) then apply again and reboot. I have been plagued with 2 routers rebooting 4 times a days and I just turned that off and made check the NTP time which was out of sync and I have had 17 hours of uptime and no reboot. First time in 2 years across 2 xr500's
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, i did factory reset after the update and still have had issues with the internet dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this:
