Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Open nat ps4 xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
08:24 AM
2020-09-17
08:24 AM
Open nat ps4 xr500
Also iv noticed since upgrading too 104 i cant get an open nat on ps4 always moderate iv tried port forwarding, upnp , too with no change.
Am running a static ip address to ps4
Message 1 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
08:26 AM
2020-09-17
08:26 AM
Re: Open nat ps4 xr500
In WAN Settings change NAT to Open, does that work?
Message 2 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
08:27 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
09:29 AM
2020-09-17
09:29 AM
What is your exact physical setup? E.g. what is your XR connected to?
Message 4 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
09:42 AM
2020-09-17
09:42 AM
1 x phone using wifi
1 x pc hardwired
2 x ps4s hardwired
1 x pc hardwired
2 x ps4s hardwired
Message 5 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
10:36 AM
2020-09-17
10:36 AM
What model of modem/router is the XR connected to?
Message 6 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
10:59 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
11:35 AM
2020-09-17
11:35 AM
Would i need to have upnp turn on on my main router ?
Message 8 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
11:39 AM
2020-09-17
11:39 AM
Okay so it is an actual router. Have you put it in modem, bridge mode, IP passthrough or put the XR WAN IP in its DMZ? You will need to do one of those things to ensure an open NAT.
Message 9 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
11:56 AM
2020-09-17
11:56 AM
The router cant be put into bridge mode or modem mode but i did put the xr500 in the dmz of the main router
Message 10 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
12:45 PM
2020-09-17
12:45 PM
I turned off upnp on main router should that be on ?
Message 11 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
12:47 PM
2020-09-17
12:47 PM
Did you put the WAN IP from the System Information page in the DMZ? You can't put the IP in that you use to access the XR as that won't work. You can leave UPnP off.
Message 12 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
12:52 PM
2020-09-17
12:52 PM
Yes i put the xr500 wan ip that i found on internet status into dmz on main router
Connection type DHCP
WAN IP 192.168.0.15
Connection status connected
WAN IP 192.168.0.15
Message 13 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-17
01:53 PM
2020-09-17
01:53 PM
Where are you seeing the NAT Type and what does it say for the NAT?
Message 14 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
01:18 AM
2020-09-18
01:18 AM
Thanks for your time freser its fixed all i did was turned on upnp on main router rebooted both xr and main router and it worked. Am still have trouble with the benchmark testing tho as its still failing and logging me out .
Message 15 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
11:05 AM
2020-09-18
11:05 AM
Are you trying the test while connected to WiFi? Not that it should make much difference but try when connected via ethernet.
Message 16 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
11:23 AM
2020-09-18
11:23 AM
Am trying with an ethernet cable i dont run wifi on pc
Message 17 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
11:26 AM
2020-09-18
11:26 AM
It always fails on the underload part of the test
Message 18 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
11:55 AM
2020-09-18
11:55 AM
What does it show exactly when it fails?
Message 19 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
12:05 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
12:08 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
12:09 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
01:01 PM
2020-09-18
01:01 PM
Great thank you. Could you check on your upstream router please to see if they block ICMP, if they do please disable that and see if the test works properly then.
Message 23 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
01:05 PM
2020-09-18
01:05 PM
Any idea where i might find that on the router ?
Message 24 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-18
01:22 PM
Announcements
