Reply
Ping heatmap not working (not showing anything on the map)
UBTVVENTY
The issue persist with any game servers i choose to ping. I tried last 3 firmwares and the all have the same problem.xr500.jpg
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 14
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Ping heatmap not working (not showing anything on the map)
What web browser/device are you using to access the router?
Message 10 of 14
All Replies
UBTVVENTY
Message 2 of 14
Netduma-Fraser
NetDuma Partner
Did you do a factory reset after the update? What is the modem/router the XR is connected to?
Message 3 of 14
UBTVVENTY
Yes i did a factory reset and nothing changed. Modem/router is Huawei HG8245Q2.
Message 4 of 14
Netduma-Fraser
NetDuma Partner
Put the XR WAN IP from the System Information page into the DMZ function on the Huawei. Then test to see if it works.
Message 5 of 14
UBTVVENTY
I put my xr on static ip and enabled dmz already. Also tried disabling firewall on huawei device.
Message 6 of 14
Netduma-Fraser
NetDuma Partner
Re-sync the cloud in the Heatmap menu then see if you can ping
Message 7 of 14
UBTVVENTY
No reaction. I can resync but the the map stays frozen.
Message 8 of 14
UBTVVENTY
When i press schedule it says script error, maybe thats a clue? Hope it helps.
Message 9 of 14
Netduma-Fraser
NetDuma Partner
Message 10 of 14
UBTVVENTY
Mozzila firefox.
Message 11 of 14
Netduma-Fraser
NetDuma Partner
Does Connection Benchmark complete a test successfully? Do you have an Adblocker on the web browser? Are you accessing the interface using HTTP or HTTPS?
Message 12 of 14
UBTVVENTY
I ended up trying a few more browsers and different settings on and off. Whaty worked for me was turning off protection on google chrome and then dumaOS started working faster and the heatmap is now on and working fine.
Message 13 of 14
Netduma-Liam
NetDuma Partner
OK that's good to hear, thank you for sharing what worked!
Let us know if you have any further questions.
Message 14 of 14
Discussion stats
  • 13 replies
  • 282 views
  • 1 kudo
  • 3 in conversation
Announcements
