× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
#### - RPC when trying to add rule to Traffic Controller
Netduma-Fraser
NetDuma Partner
Message 1 of 11
Phantomblu
Apprentice
Re: #### - RPC when trying to add rule to Traffic Controller
Yes
Model: XR500|Nighthawk Pro Gaming Router
Message 2 of 11
Netduma-Fraser
NetDuma Partner
A dev has asked if you could do a factory reset and then try to use the feature using an Incognito web browser window to see if it works then.
Message 3 of 11
Phantomblu
Apprentice
Re: - RPC quando si tenta di aggiungere una regola al controller del traffico
already tried nothing to do
Message 4 of 11
Netduma-Fraser
NetDuma Partner
Thank you for the update, I have relayed it to the developer.
Message 5 of 11
Netduma-Fraser
NetDuma Partner
Do you have any IPv6 devices listed in the Device Manager?
Message 6 of 11
Phantomblu
Apprentice
Re: - RPC una regola al controller del traffico
IPv6 is enabled for now only as automatic detection connection type Tunnel 6to4
Message 7 of 11
Phantomblu
Apprentice
IPv6 is enabled for now only as automatic detection connection type Tunnel 6to4.
but in Device manager there is only my PC ipv4 no wireless .
Message 8 of 11
Netduma-Fraser
NetDuma Partner
Thank you, I have relayed that to the developer.
Message 9 of 11
Phantomblu
Apprentice
 Update I think I have found an answer to the problem .
 Looking at the area of the I came up with an idea that is to change language to the Dumaos system .
 I went from the Italian language which is my language to English and voila' suddenly it all worked. In practice with English traffic rules works   but  not in Italian ...
Message 10 of 11
Netduma-Fraser
NetDuma Partner
Well done for figuring that out! We should be able to reproduce this easily and get it fixed, thank you! I've let the developer know.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2464 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
