×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RX 500 - destiny 2 problem with geo filter
Stami
Tutor
Re: RX 500 - destiny 2 problem with geo filter
non ce differenza tra usarlo o non usarlo . un pezzo di plastica da 150 euro .
Message 126 of 143
Rsmith2001
All you goobers are triggered cuz you don’t know how to do it gheeez, go learn it or pay someone to teach you. Instead of saying that there product is crap when in reality it’s the people using it that are crap 😉
Message 127 of 143
Stami
Tutor
dimmi chi devo pagare per inparare,senza venire truffato e lo faccio volentieri
Message 128 of 143
Rsmith2001
I can teach you and show proof I can do it.
Message 129 of 143
Stami
Tutor
con xr500 o altri metodi ....
Message 130 of 143
Rsmith2001
I have the xr 500 and use open vpn, threw a black box. It’s one of them things that sound hard to do but it’s pretty easy
Message 131 of 143
Netvirus
Qualcuno ha capito come usare il router? Io ho amici che ancora creano Ghost lobby con il router qualcuno sa come fare? Ho provato con Linux e Ubuntu ma non si abbinano le PlayStation
Message 132 of 143
Rsmith2001
Must be doing something wrong then, Ubuntu is what you use, works like a charm!
Message 133 of 143
Stami
Tutor
io pensavo fosse qualche impostazione all interno del modem. se e ubuntu  non e facilissimo
Message 134 of 143
Stami
Tutor
non serve il modem se usi linuxx
Message 135 of 143
Stami
Tutor
pensavo a qualche impostazioni all interno del modem .
Message 136 of 143
Rsmith2001
Only way to do it is threw Linux or Ubuntu, nothing in the setting of net gear can change it anymore, (hybrid vpn) allows you to do these lobby’s
Message 137 of 143
Dunaz
Guide
Hello, I have Linux and all the packages for the lobbies, I wanted to ask: you have to connect pc_router_xbox, then you have to have your own vpn I have and the one that installs the initial setup thanks
Message 138 of 143
Stami
Tutor
qualcuno mi sa spiegare il sistema di ghost lobby con Ubuntu. io ho gia ubuntu , ma non so cosa scrivere sul terminale per far si che le play5 si registrino . se qualcuno mi puo spiegare bene in privato posso pure ricompensarlo.
Message 139 of 143
Stami
Tutor
se puoi insegnarmi scrivimi in privato cosi ci mettiamo d accordo. la mia email matteospartan98@gmail.com
Message 140 of 143
Rikuzamiii
ciao hai qualche notizia sulle ghost lobby su destiny, perche' ho visto che qualcuno riesce ancora a farle
Message 141 of 143
Rikuzamiii
hi, can you still do ghost lobbies in destiny 2 with netduma, if yes can you tell me how you do?
Message 142 of 143
Dunaz
Guide
Probabile ci sia un metodo con net duma ma nessuno lo rivela,,,, si può fare con Linux ma devi cercare altrove,,, puoi fare anche senza router devi avere 2 biglietti a 7 per squadra ed il sistema è sempre lo stesso
Message 143 of 143
Top Contributors
Discussion stats
Announcements
Orbi WiFi 6E
