- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Traffic Controller - Timezone issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX5400 WiFi Gaming Router (XR1000)
Firmware Version 1.0.0.52_1.0.38
DumaOS Version 3.0.187
I am EST in the U.S.A.
I went in to the Traffic controller and set up a couple of rules and noticed they are an hour off.
Steps to see the difference:
Go into Settings-->Administration-->NTP Settings
Select GMT-05:00
Check the box to Automatically adjust for DST
Save
The time shows correct here in the NTP settings area:
Now if you go into System Information and view the System Info box, it is an hour behind.
If I untick the DST box, both times are the same but my router time is an hour behind Daylight Saving.
As a workaround during the summer (DST), I will be using the time zone GMT-04:00.
Just wondering if this is a known bug that will be fixed or if this workaround is the only fix.
I hope this helps someone else too.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Traffic Controller - Timezone issue
That did the trick. The timezones are split up a little more there.
Selecting Eastern Time from System Information-->ellipses-->advanced-->Timezone and checking the box for DST set both correctly (DumaOS and System). Thanks for pointing me in the right direction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
