- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Upload Bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Upload Bufferbloat
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Fraser wrote:
Okay so that was the issue then, doing it all from the dashboard? Are you able to have something else handle PPPoE to see if that is the case?
Are you saying setup using DHCP DMZ like last time with gateway router and xr500 setup through the lan port on it? Or do I need to try and get a completely seperate router/switch for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes have the gateway handle PPPoE and just put the XR in the DMZ if you can and then try.
Okay will give that a try and see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I used The Setup Wizard to get setup through DHCP. The QOS bug came back and isn't capping the upload again. I will just factory reset again..
https://imgur.com/a/Ytx5esQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Jawwk wrote:I used The Setup Wizard to get setup through DHCP. The QOS bug came back and isn't capping the upload again. I will just factory reset again..
After factory reset upload cap is working but now Connection benchmark just keeps loading and not testing.
https://imgur.com/a/JfTbIu9
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I can see you've got AdblockPlus enabled even in Incognito mode, could you disable this, refresh the page and see if it works correctly after that please?
Adblock's fully disabled no effect
https://www.youtube.com/watch?v=RiEsCRrBDms
Upload cap is working after factory reset but connection benchmark ins't even loading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Fraser
Does the Connection benchmark use https to get info? I tried using Microsoft Edge to get bufferbloat results on dsl reports and https speedtest didn't work at all?
https://www.youtube.com/watch?v=hs-qIxIise4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks for all the information. There should be a firmware next week I believe so lets see if it is resolved then.
Okay, thankyou for all your help so far. Hopefully it will get fixed so I can use this router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
take your device out of traffic prioritization, for some reason it cancels qos
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I try to do that but i dont know how? Can you explain how it works?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- « Previous
- 1
- 2
- Next »
User | Count |
10 | |
6 | |
5 | |
4 | |
3 |
