× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR450 DumaOS 3.0 Firmware
DredPirate13
Apprentice
I have been keeping an eye on this unfolding of the DumaOS 3.0 beta for the the XR500 and haven't really seen anything for any other systems. I have an XR450 and I was wondering if the beta for the XR500 is also going to be for the XR450 or if the XR450 will have its own beta?
Message 1 of 21
Accepted Solutions
TimChang
NETGEAR Employee
Re: XR450 DumaOS 3.0 Firmware
Message 4 of 21
All Replies
Guru
I have one too. Waiting patiently. Smiley Wink
Message 2 of 21
Netduma-Fraser
NetDuma Partner
We will be releasing a version for the 450 very soon.
Message 3 of 21
TimChang
NETGEAR Employee
Message 4 of 21
Any news for XR700 @TimChang ??
Message 5 of 21
Netduma-Fraser
NetDuma Partner
That should also be coming very soon!
Message 6 of 21
thank you for the update, keeping my fingers crossed!
Message 7 of 21
Guru
So here are my initial results and findings after loading v106 on my XR450:
I see this message when using MS Edge:
I'll try some other browsers as well to check this.
1st speed test thru the setup wizard is working:
1st Connection Benchmark test results WITH QoS enabled:
2nd Connection Benchmark speed test WITH QoS Disabled:
Ooklas speed test app results with QoS Disabled:
I see that the Connection Benchmark results are not reporting anything near 900Mpbs. This seems to have migrated over from other Duma testing I have found. Smiley Wink
All these speeds results are from the XR450 connected double NAT behind a R7960P router thats connected to a CAX80 running in modem only mode.
Continued testing to come...
Message 8 of 21
Netduma-Fraser
NetDuma Partner
Don't access with HTTPS, I don't think that is really fixable. Speeds through benchmark should coincide with the current state of the 500 so that will be improved upon. Definitely need to fine tune QoS there!
Message 9 of 21
Guru
I haven't tried accessing HTTPS. Why I was surprised to this after loading FW and I factory reset and started walking thru the setup wizard.
I presume this is coming from the FW?
Message 10 of 21
Netduma-Fraser
NetDuma Partner
That is odd, if you try to load it in an incognito window does it happen again even when using http?
Message 11 of 21
Guru
No I don't see that window appear, if this is correct:
It gave me the log in screen then the dashboard screen loaded...
Message 12 of 21
Guru
I closed the private window and logged in with the non private Edge browser and I got the log in screen. After I hit enter, "Your current browser does not support HTTPS on DumaOS." appears.
Message 13 of 21
Guru
I tried Opera and Opera GX browsers and they both don't display the HTTPS message window.
Message 14 of 21
Netduma-Fraser
NetDuma Partner
I've made a topic for the HTTPS message but got a reply from a dev that it is expected behavior as the browser tries to be clever and redirect you to HTTPS and that message is normal when accessing HTTPs.
Message 15 of 21
Guru
Smiley Wink
Message 16 of 21
Guru
Ok, went online yesterday with the XR450 as main host router with Beta FW loaded. Looking good thus far. No other configurations set up currently. I have two EX7700s connected for additional coverage.
One thing I notice the NH app doesn't work with iOS 14 which is a Apple issue.
Android App work, however doen't show the two connected EX extenders.
Otherwise, XR450 seems to be working nicely.
Still offers Full Cone NAT support:
http://nattest.net.in.tum.de/individualResult.php?hash=ebbde5f6c705738645660b958b80f0ac
Thank you for keeping NAT Filter in the UI.
Message 17 of 21
Guru
My Mac Book Pro with OSX BigSur Beta 10 loaded and speed test with the XR450 on 5Ghz. !300Mpbs:
Not bad for 5Ghz AC.
Message 18 of 21
Franklyn-Turner
Apprentice
More XR450 DumaOS 3.0 Firmwares (updates) ?
Thanks for this where do i go for updates on more beta files ?
Message 19 of 21
Netduma-Fraser
NetDuma Partner
Re: More XR450 DumaOS 3.0 Firmwares (updates) ?
We'll post new updates to this forum.
Message 20 of 21
Franklyn-Turner
Apprentice
Great! thank you! 🙂
Message 21 of 21
Discussion stats
  • 20 replies
  • 9929 views
  • 13 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
