Reply
#### - XR450 - HTTPS message appears when accessing HTTP on Edge
Netduma-Fraser
NetDuma Partner
@FURRYe38
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR450-DumaOS-3-0-Firmware/m-p/19882...
So here are my initial results and findings after loading v106 on my XR450:
I see this message when using MS Edge:
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: #### - XR450 - HTTPS message appears when accessing HTTP on Edge
Got a reply from a dev that it is expected behavior as the browser tries to be clever and redirect you to HTTPS and that message is normal when accessing HTTPs.
Message 2 of 3
Guru
OK, sounds good. Something I would document in a FAQ if possible.
WIll keep this in mind when using Edge. Smiley Wink
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 3
Discussion stats
  • 2 replies
  • 313 views
  • 1 kudo
  • 2 in conversation
Announcements
