× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
#### - XR450 - Settings not saving correctly
Netduma-Fraser
NetDuma Partner
@Mistakes
"Everytime I log into the router the greeting message still pop up even though I have already skipped them in the past. For example clicking on the QoS tab brings up the "welcome" popup and even has a loading "applying settings" notification. Rebooting the router changes nothing, the behavior returns every time you log in.
2. I cannot disable QoS. If I check "disable qos" it will show the checkmark but if I swap to another page and return to the QoS page the checkmark is missing again which leaves QoS on."
"I tried Firefox normally, then Firefox incognito and finally Microsoft Edge(the chrome version). Same behavior in all tests."
"Log in > Click QoS tab > Welcome to QoS popup (applying settings pops up at the same time) > Click skip tour > Click the hamburger menu at the top left next to congestion control and select "disable QoS"> "disable all QoS features?" pops up > Click proceed and "applying settings" shows > disable QoS box is now checked > refresh page and "applying settings" shows up > Click the hamburger menu and see the check mark is now gone after refreshing the page."
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/Issue-reporting-thread-POST-NEW-ISS...
Message 1 of 7
Guru
Re: #### - XR450 - Settings not saving correctly
@Mistakes
Have you factory reset the XR router after updating FW?
Be sure to clear out ALL browser caches...
I can confirm that the router tour keeps happening when I log in.
I can't reproduce not being able to disable QoS. Mines disabled currently. I've used Edge and Opera to test my 450:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR450-DumaOS-3-0-Firmware/m-p/19882...
Message 2 of 7
Mistakes
Tutor
@FURRYe38
Yes a factory reset was done before and after flashing dumaOS 3.0. I tried with Firefox incognito, Microsoft Edge and Fraser also requested I try with chrome which I didn't have installed and this happened with a fresh install of that so It's not a browser problem.
Message 3 of 7
Guru
Ok, odd that it's happening on yours. Mines ok. I just re-enabled QoS on mine to check and rebooted using Opera...QoS is now enabled.
Hopefully the team and check this out for you...
Message 4 of 7
Guru
Only thing I might try is to re-load the FW again. Use a wired PC, Edge or Firefox or Opera. Factory reset. Clear ALL TIME history caches. Then setup from scratch then try to change the QoS setting...
Message 5 of 7
Mistakes
Tutor
@Netduma-Fraser
After another day of messing around with the router I was able to solve this problem. It was ultimately still related to ipv6.
ipv6 enabled = QoS cannot be disabled
ipv6 enabled + reboot =  Qos cannot be disabled
ipv6 disabled = Qos cannot be disabled
ipv6 disabled + reboot =  Qos CAN be disabled now.
Message 6 of 7
Netduma-Fraser
NetDuma Partner
Thank you for the update, we have fixed the IPv6/QoS issue in the next version so hopefully it will resolve this also.
Message 7 of 7
Discussion stats
  • 6 replies
  • 1873 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
