- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 V2.3.2.120 no funcion geofilter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Buenas a todos, hace 2 dias no me funcionaba bien la velocidad , estaba descompensada, esta con la version V2.3.2.120.
Con el router de la compañia todo perfecto, decidi baja de version a la V2.3.2.114 y todo ok menos agregar dispositivos en geofilter, instale de nuevo la V2.3.2.120 y tampoco me deja agregar disposotivos.
Lo he reseteado y sigue igual.
En el Ping Heatmap marcando Call of duty Moder warfare y warzone no salen servidores N/C ms
Gracias.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 V2.3.2.120 no funcion geofilter
Did you factory reset the XR500 after changing firmwares? This is often required as it means no low-level code is left often from the previous firmware. Try that and let us know if you have any further issues.
We're aware of the problem with Ping Heatmap for CoD and will be pushing another update today to fix this.
