Orbi WiFi 7 RBE973
Reply
XR500 sty in a loop after update DumaOS 3.0 2.3.2.108
blanc16
Tutor
hi there
i have problem whit my router
when i whas updateing my XR500 whit the firmware 2.3.2.108
i try to reboot dint work
turn the router off and on didnt work ether
how cane i restore this
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 6
Accepted Solutions
Guru
Re: XR500 sty in a loop after update DumaOS 3.0 2.3.2.108
You can try factory resetting it. Push and hold reset for 7-15 seconds while its powered on.
If that doesn't work, it might have corrupted firmware. you can try recovering it using tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 6
All Replies
Guru
Message 2 of 6
Netduma-Fraser
NetDuma Partner
I can't see the picture but you may need to just clear the web browser cache/cookies and then refresh the page. If not the TFTP method above is a good plan.
Message 3 of 6
blanc16
Tutor
hi plemans
thanx fore the info
the tftp workt me
Message 4 of 6
blanc16
Tutor
hi
it whas not my browser that whas hanging
it whas the router didnt go to the dashboard
it sty in the upgrade mode
but it is fix now
thanx all
Message 5 of 6
Guru
Glad it worked!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2881 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
