Reply
XR700 - DumaOS 3.0 Beta Firmware
Re: XR700 - DumaOS 3.0 Beta Firmware
pic is there.
Model: XR700|Nighthawk Pro Gaming Router
Message 126 of 306
Message 127 of 306
Message 128 of 306
View post on imgur.com
<blockquote class="imgur-embed-pub" lang="en" data-id="8oUT6r1"><a href="https://imgur.com/8oUT6r1">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Message 129 of 306
Netduma-Fraser
NetDuma Partner
Got it thanks, in the top right of the interface - the 3 dots icon, if you go there and to Advanced you can change the timezone, does it have the correct one there? When you then apply that does it appear as being used in System Information?
Message 130 of 306
no it don't even have it there.
Message 131 of 306
it's bugged whenver i change it to other timezone etc even tho it's not showing that timezone it goes to other state weird. it don't save whenver i go to other timezone to.
Message 132 of 306
whenever i change the timezone it don't save either.
Message 133 of 306
ohhh other thing idk if a bug are not i even reseted the router etc is it says there an update but there no update.
Message 134 of 306
Netduma-Fraser
NetDuma Partner
I believe they will align the timezones to use our list instead so that will come in future. Just use the closest you have in terms of timezone and it will work, it doesn't impact the router functions. Do you click apply at the bottom of the page once you've selected it? That is normal because you're on a beta version so it gets confused, you can ignore it.
Message 135 of 306
MGS78
any new for the update of the beta ?
Message 136 of 306
Netduma-Fraser
NetDuma Partner
The 700 beta came in last so most likely the 500 will receive another build before the 700 but we're working on it as fast as we can.
Message 137 of 306
Redarkside34
Tutor
Any news on what features the next build going to have
Message 138 of 306
Netduma-Fraser
NetDuma Partner
The features are all mostly there so unlikely you'll see any new ones for the moment, will be bug fixes primarily.
Message 139 of 306
Black_file
Will RApps Store be available on netgear router or not ?
Message 140 of 306
Netduma-Fraser
NetDuma Partner
Yes it will be in the future but I don't have a date for that currently.
Message 141 of 306
busolof
Star
Hey,
hybrid vpn some times failed to load have in that script :
keepalive 10 60
but setting offline hybridvpn and wait one minute and setting online is great again.
not sure if that bug
Message 142 of 306
Netduma-Liam
NetDuma Partner
OK, did this just occur once or is something that keeps re-occuring and you need to disable and re-enable it to resolve?
Message 143 of 306
busolof
Star
Hey,
need to disable and re-enable it to resolve that.
Message 144 of 306
Netduma-Liam
NetDuma Partner
OK, approximately how long is the time between failures? Does this happen once a day or more/less?
Message 145 of 306
busolof
Star
hey,
not sure how long time between failures, can take about from 4 days to 14 days not sure why.
Message 146 of 306
Netduma-Liam
NetDuma Partner
OK thanks, could you also just confirm what firmware version you're running?
Message 147 of 306
busolof
Star
Hey,
runing XR700 V1.0.1.34_Dumaos3.0_6
Message 148 of 306
Netduma-Fraser
NetDuma Partner
Make sure you add it with the two dashes so:
--keepalive 10 30
if these options are still present in the config then remove them:
ping 15
ping-restart 0
ping-timer-rem
Message 149 of 306
busolof
Star
Hey,
have thanged to
--keepalive 10 30
and they you write too is not in that script.
Message 150 of 306
Discussion stats
Announcements
