- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
duma os 3.0 V2.3.2.104 Lots of errors
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel like this version has way to many bugs i cannot delete anything device under QOS without getting errors. Is there another version out right now that may not have so many issues, also when i try and setup Call of duty pc for QOS it doesn't work cannot find the ping only shows host tickrate the majority of the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: duma os 3.0 V2.3.2.104 Lots of errors
I think that this may be a problem which is caused by cached elements from an older version still being stored in your browser...
Could you try loading DumaOS in an Incognito Window or a Private Window? This will load DumaOS with the cache cleared and hopefully should fix your issue. Let me know!
- Mark as New
- Bookmark
- Subscribe
- Permalink
unfortunately it did not fix the issue. do you have a firmware i can backup too in the mean time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
format your router when i did that fixed it 100%
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser im not having alot of issues what issues u refurring to
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member wrote:
That’s really funny the way you said that it’s true though my network is also complex but I’m not having as much issues because I formatted my router and it works amazing now i’m not getting Any error codes or anything
@Retired_Member What do you mean by "formatting"? Is that different from doing a factory reset? i.e are you wiping all software from the router and then reflashing using TFTP method? If so Step by Step instructions would be useful...Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser what happened to the rapp store
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
after doing the factory reset after i updated to 3.0 V2 3.2.104 fixed all my problems except I cannot find h5 on xbox geofilter or any halo on the geofilter on pc. It only shows the halo mcc under ping heatmap
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Netduma_Alex
Can we upload or give us access to the DumaOS version before this one? In case anyone needs to downgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello netgear community
i wanna know because i am still noob at negear duma os etc.
is there a way to see the new fifa 21 servers location,because i bought xr500 recently and installed duma os 3.0 beta
when will the new servers of fifa 21 be added?
- Mark as New
- Bookmark
- Subscribe
- Permalink
