× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ping wont show on xr500
William3087
ping wont show on xr500 in beta
Message 1 of 7
Netduma-Fraser
NetDuma Partner
Re: ping wont show on xr500
Thanks William, just to double check, does it work if you do a manual ping?
Message 2 of 7
William3087
no it dosent work
Message 3 of 7
William3087
the server is in east cast
Message 4 of 7
Netduma-Fraser
NetDuma Partner
Does it ping successfully for servers elsewhere and is it just a problem in that region?
Message 5 of 7
William3087
i tested in the usa and it dosent shoe the ping
Message 6 of 7
Netduma-Fraser
NetDuma Partner
Okay thank you, can you just provide a screenshot please as it will be helpful for the devs, then I'll make an internal ticket.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1538 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
