× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
stuck in the menu
Criscros1989
Initiate
stuck in the menu
Hello everyone,
I have encountered ping problems for the umpteenth time
ping host and geomap, I don't see any server in the map but the filter works, some time ago I solved it by reloading the fw, now I reloaded the fw .120 but I haven't solved it, so I reloaded the .114 but I'm stuck in this situation for hours, the haerd reset button has no consequences, I can't update the fw, not even from ftp, ip4 in manual and when restarting with an intermittent orange LED I press put, but it immediately stops at block # 0, internet wan and lan work correctly anyway, ping the router works good
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Criscros1989
Initiate
Re: stuck in the menu
solved whit continius trying factory reset button, then now work perfect finally
Message 2 of 2
Discussion stats
  • 1 reply
  • 585 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
