- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
this series is for gaming first
- Mark as New
- Bookmark
- Subscribe
- Permalink
i also wanted everyone to keep in mind it doesnt matter if you have the fastest ping, if your connection is unstable you are probably in worse shape than a guy with high ping with stability, the reason ive posted this is to remind people that if an app that really does do anything for gaming needs attention save the info for later days. right now qos is not working high prioroitization not working upnp not working anti bufferbloat not really working great. geo filter is not working properly, and games need to be added to profile for all gaming devices not just pc. ping heat map should coexist with geo filter and maybe away qos and anti bufferbloat should be auto detect depending on what game you are playing. i bought my xr500 so i could play at a top tier level at something i loved to do.i will honestly tell you for 2 years its been a joke, cause i live nowhere close to any servers to any game i like to play, but the one thing i loved about my xr500 was i could set my geo filter to strict and not pick up a dedicated server outside my circle, but in the beta if i dont have filetered on, strict is useless it tries to put me all over the globe. and with games like call of duty modern warfare where the sbmm is so wacked out, it gets frustrating. i understand everyone wants new apps but if these apps are not optimized to work together and be useful then whats the point. ping heat map is like seeing a lambo but not having a lambo, why waste your time with it. connection benchmark the same if it cant monitor the speed with anti bufferbloat and only reads qos its not helping. auto speed adjust another thing thats really in the way if qos is broken and only helps with either upload or download not both. and fiber gig internet is being pushed everywhere if the router cant get but 1200 pasthrough its not helping because its picking upload or download and drastically nerfing the speed for the other, which is causing major lag and buffer bloat issues in games.
this is a beta to test these things see what we can do to get these to work properly and effectively. no need to add glitchy features is they dont really help or can be optimized to be a better app. yes ping heat map im talking to you, why cant we pick the servers from there that we want to play on and block the ones we dont, still feel like this app is useless if it is not somehow combined with geo filter. there really needs to be something that analyzes your gaming traffic and automatically adjust for a more smooth and responsive gaming expierience
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: this series is for gaming first
- Mark as New
- Bookmark
- Subscribe
- Permalink
1 qos is strangling bandwidth down load speeds on my gig speed only registers 500 out of a gig while upload speed registers 850 plus.
this makes upload un stable, and inconcistent.
2 geo filter strict mode supposed to ensure you do not connect to dedicated servers out side your server, but if you turn off filtering mode it wants to connect outside the circle. filtering mode supposed to restrict players from your circle.where as i said strict blocks dedicated servers, but if i turn off filtering mode, strick mode stops blocking dedicated servers from my circle.
3 traffic prioitization. if you try to put a device in traffic prioritization and use the advanced settings, qos stops working.
4 upnp dmz are causing traffic prioitization to not put traffic packetts
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. The Geo-Filter settings only work if you have the Geo-Filter in Filtering Mode, that is expected behavior.
3. By QoS what do you mean, CC, Allocation, TP? What rules are you entering?
4. What rules are you entering for TP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
QoS enabled for me is not slowing my 1Gb ISP service on my 450:
