× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
2.4 Wifi drops intermittently on Nighthawk X4S
TDS21
Follower
Hello, wondering if anyone has the same issue on firmware v1.0.1.56. 2.4ghz signal drops and rejects any connection for 10-15mins before it recovers. 5ghz signal works fine though.
Very annoying as all smart home devices are on 2.4ghz signal. Have tried searching and there's articles suggesting downgrading firmware to v1.0.2.52 which I've tried doing but router won't install it saying it's the wrong firmware.
Any help would be much appreciated. Cheers.Smiley Happy
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 3
Guru
Re: 2.4 Wifi drops intermittently on Nighthawk X4S
Did you try a factory reset after the firmware changes? And then manually resetting the device back up? Not using a backup configuration?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Guru
Be sure to post about this over in the DSL modem forum for your model modem:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 617 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
