Reply
2 ISP provided IP Addresses
Woodshopguy
I'm am considering a purchase of a pro gaming router.  I'm looking for some assistance with which one to get.  Currently my ISP provides me with 2 static IP addresses.  One for my gaming and 1 for my non-gaming in home network.
Do any of the nighthawk routers accomondate this type of setup?
Thanks
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: 2 ISP provided IP Addresses
Hi Woodshop, so to clarify you want a router that can handle two separate WAN connections instead of using two separate routers - 1 for each connection?
Message 2 of 4
Woodshopguy
Yes, one router, that is because the ISP is not providing 2 cables to the wan, just 2 static IP addresses on the one WAN cable.
Message 3 of 4
Netduma-Fraser
NetDuma Partner
I don't believe that is possible, it's quite a rare use case (even more rare for just one WAN cable as far as I'm aware). I can double check but it's unlikely.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1858 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
