× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Adblock
OlegP
Apprentice
Adblock
Hi
I got a popup to disable my adblock when I loged into the admin page and then I saw this javascript running on the router's page when I checked the logs. Is my router infected with malware?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: Adblock
No it's not, that's absolutely fine! It's because it can interfere with the interface thats why we recommend disabling it.
Message 2 of 4
OlegP
Apprentice
Re: Adblock
OK then what's the deal with the script's name?
Message 3 of 4
Netduma-Fraser
NetDuma Partner
Re: Adblock
Might be a joke from a dev, not sure but I'll double check for you. Your router won't have malware I can assure you.
Message 4 of 4
Discussion stats
  • 3 replies
  • 2201 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
