× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Anti-Bufferbloat not working on upload speed
Eagleq8
Tutor
Hello.
I have a problem with the anti-bufferbloat. It does not limit the upload speed when I am playing a game even though it is working perfectly on limiting the download speed. I have searched for this problem and saw many posts regarding it and it was acknowledged as a bug and that it will be fixed with version 3.0. I have just updated to 3.0 and the problem still persists which sucks because anti-bufferbloat is basically the reason I bought the router. My cousin has the same router, ISP and download/upload speed as me and his is working completely fine. Any idea on how to fix this problem?
Thanks
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Anti-Bufferbloat not working on upload speed
Please post about this in the beta section and let us know what your connection type is e.g. using IPv6, VLAN, PPPoE, DHCP identifiers
Message 2 of 3
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 3
Eagleq8
Tutor
I did a factory reset after updating to 3.0 and now it works perfectly! Very good update. Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 1641 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
