Orbi WiFi 7 RBE973
Reply
Automatic Latency Reduction Program Location?
SouthernGypsy
Apprentice
When I was first setting up my XR1000v2 I remember it going through a rutine where it said it was going to test my initial latency/ping rates and perform tests and make adjustments to automatically improve it. Which it went through a rutine and then said it had optimized the settings resulting in a lowered ping rate.
I can't find where to go to re-perform that. All I found was the "Auto-Setup" under the QoS congestion control menu but that does not look like what it did before. The test I am reffering to had nothing to do with QoS but rather the overall initial latency....
Does anyone know where the option is to re-perform that latency reduction rutine?  (without having to reset the entire router as all my other settings are good).
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: Automatic Latency Reduction Program Location?
That is what the Auto Setup does, that's how you do it without doing a factory reset to do it the way you saw before
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 502 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
