- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best settings for xbox one and xr450
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best settings for xbox one and xr450
What FW is currently loaded?
Wired connection between the router and xbox is preferred.
Disable "Instant ON" feature on the xbox.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Set WPA2 and AES only for wifi security.
Disable IPv6, MIMO(if you don't have any MIMO supporting devices) and 160HT on the router.
Review this as well:
http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is 2.3.2.32
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend you read the DumaOS Optimal Settings guides. They include how to get an open NAT and how to setup Geo-Filter and QoS to get the best ping:
http://support.netduma.com/support/solutions/folders/16000090646
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP modem I believe has a router already built in:
Modem Combo Units:
Couple of options,
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
@Sur_justin wrote:
model number of ISP modem is 5268ACFXN not sure what mfr is though
