Reply
Bridge Mode in XR700
sqb
Hello.
I have two routers XR700 and I want to connect them with each other via 802.11ad.
So I tried to set the bridge mode on the one of them according it:
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
As i read this article applies also to the XR700, but I don't have such options in my routers (Wireless Bridge option doesn't exist).
Could someone help me with this? How to set it on XR700?
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 9
Netduma_Alex
NetDuma Partner
Re: Bridge Mode in XR700
So both routers are XR700s?
Message 2 of 9
sqb
Yes, both routers are XR700
Message 3 of 9
Guru
Even if you could get this working, why would you want to connect them via the wireless AD? Its effective range is 30 ft and struggles with any obstacles in the way. Its basically good for same room usage for high bandwidth applications.
https://arstechnica.com/gadgets/2016/12/802-11ad-wifi-guide-review/
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 4 of 9
Netduma_Alex
NetDuma Partner
What firmware version are you using?
Message 5 of 9
Guru
Wireless bridge mode isn't supported on XR routers. Only router and AP mode.
@sqb wrote:
Hello.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 6 of 9
Netduma_Alex
NetDuma Partner
But XR700 is mentioned in the corner of the article as relevant.
Message 7 of 9
Guru
I would get in contact with @Christian_R to confirm this. From what I've seen on my XR450 and when I had the XR700, wireless bridge mode is not in the UI. Never has been. Possible the inclusion of the XR series in the article maybe incorrect.
Something to see what NG says.
Message 8 of 9
Netduma-Fraser
NetDuma Partner
As above, I've not ever seen this option on the XR700. Maybe it was planned to be included and then removed and the article wasn't updated, either way I think the article is incorrect in this instance.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1914 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 6E
