× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CONNECTION UNSECURE
rdarby86
Follower
CONNECTION UNSECURE
firmeware 2.3.2.40
windows 10
chrome
when loging into dashboard i am promted with, connection is unsecure, how do we fix this?
Thanks
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: CONNECTION UNSECURE
Are you trying to connect using HTTPS?
Is this in the top left corner of the URL bar you're talking about? If so it's not important as you do not enter any sensitive information on the interface. The interface is also only accessible locally so no one else can access.
Message 2 of 2
Discussion stats
  • 1 reply
  • 813 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
