- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can you connecting XR500 to XR300 wirelessly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can you connecting XR500 to XR300 wirelessly?
The XR300 doesn't have a repeater/extender mode.
You could always try connecting them via powerline or moca adapters (powerline over coax) with the XR300 in ap mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CoolestJake wrote:
So the way the house is wired the up and down stairs don’t allow me to use those.
It has completely separate electrical circuits? That's all you need with Powerline.
That's a strange one. Never heard of that before. Are you sure?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've seen it with homes that setup the basement for a seperate living quarters to rent out. Or for a mother in law suite in the basement.
Not common but does happen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CoolestJake wrote:
Ya I’m sure because I tryed it with my computer I put the router downstairs plug everything in and it showed it work but it wasn’t actually receiving the internet.
Tried what with your computer?
That tells us nothing about your mains circuit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. That's a much clearer explanation. You tried with Powerline and it failed!
Your experiment seems pretty thorough. It rules out some of the "can't connect" events that can trip people up. Sometimes, actually quite often, it is because they haven't set up their PCs properly. You've ruled that out.
If you can get powerline to work in one room and then move the plug to a different mains socket and it doesn't work, that's a pretty clear indicator that the mains circuit is the issue.
Is there anywhere in the house that you could use Powerline to feed the second router and the use the wifi from that location? Not perfect, but maybe it could spread the wifi a bit further.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
