- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot VPN some devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Just wondering, I have managed to use Hybrid VPN with some of my devices, like computers and Macs, but if trying to VPN something like an Xbox it stays shaded out and you cannot seem to do anything with it? Well the services part anyway. Does this just mean the entire xbox is being VPN'd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot VPN some devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Just wondering and instead of starting a new thread. Should the VPN be reconnecting automatically if it drops out.
At the moment it drops connection and doesn't seem to reconnect.
Thanks
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dan,
I'm not actually sure - I would need to check with the dev but he's not in today. Are you having regular VPN drops? If so, it's probably worth using a different server of even different provider if possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thanks. It normally works fine on other devices. Only via the router, it drops out, and if it drops out the traffic stops as it is meant to due to the setting I have.
An auto reconnect would be good though. I will try one of their other servers and see.
Thanks
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Dan - hope that one works better for you
