×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Changing BT hub to XR1000
Russ73
Hi
I have spent all morning trying to set up my new XR1000. My ISP is BT and I was using their Home Hub. Once I set up my XR1000 it comes up " No Internet Connection"
I was wondering do I need any Info from BT to put into my new router
Firmware v1.0.0.58
can anyone please help me
Message 1 of 5
Guru
Re: Changing BT hub to XR1000
are you going straight from an ONT to the netgear?
Or going bt hub---->netgear?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Netduma-Fraser
NetDuma Partner
As above are you replacing the hub with the XR as it should be straight forward otherwise. If you are check the hub network settings, there may be information there such as PPPoE that is required for a connection that you will need to enter on the XR.
Message 3 of 5
Russ73
I am going straight from BT ONT to the Netgear
Message 4 of 5
Netduma-Fraser
NetDuma Partner
You'll need to check the hub network settings to see if there is anything you need to put in the XR
Message 5 of 5
Discussion stats
  • 4 replies
  • 391 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
