- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection Dies Randomly With QoS Enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having a weird issue with my Nighthawk X500 Router. With QoS enabled, the connection will drop randomly. When this happens, I can play with the QoS slider and the connection will come back for a few seconds before dying again. Connection will drop on all ports and wifi. This doesn't happen at all with QoS disabled.
Anyone experience this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection Dies Randomly With QoS Enabled
What devices are you using when the connection drops?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there - this is very unusual. What mode is your Anti-Bufferbloat set to when these drops occur?
What is your total bandwidth? How much are you reducing the sliders to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
450/30
80%
XR500 V2.3.2.40
Arris TM1602 Cable Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cable Modem to Router. One PC plugged into router. Everything else is wireless.
No PPPoE or VLAN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ensure cable between ISP Modem and router is of good quality. CAT6 is recommended.
You might manually downgrade to v32, factory reset, power OFF the ISP Modem for 30 seconds then back on. After setting up minimal router settings, run a wired PC speed test with a PC and check speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the link to the previous firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Could you downgrade back to this and see how it performs there. Thanks
