× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
D7800 x4s modem only
Masonstorm
Follower
Trying to set up xr500 with d7800 x4s which has modem only facility - if I have two netgear products on same network how do I access www.routerlogin.net which one will it default to cannot find any documentation on x4s for modem only mode
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 3
BIG_DOG
Luminary
Re: D7800 x4s modem only
if you have set it to modem only mode and connected it to XR500 then you can try using 192.168.1.1. routerlogin should be accessible for xr500 and to access your d7800 you may have to connected wired directly from that to your pc in order to take it out of modem only mode if you have to.
Message 2 of 3
Netduma-Fraser
NetDuma Partner
Further to what Big Dog has said the XR500 would have detected the interface IP clash and given the XR500 a different IP to be accessible from. Accessing using the IPs exclusively will get you to the correct interface.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2552 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
