× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
DDNS Options
bgoodin
Follower
DDNS Options
I use OpenDNS for some basic filtering on my network (better safer than sorry). In the past my router has been configured to communicate to OpenDNS what my IP is. I was dissapointed to find that the RX500 only supports no-ip.com and dyndns.com. I have setup a machine within my network to report to OpenDNS with their updater. It would be much nice if this would happen from the router. Has anyone been able to rig a solution just using the router? Are there any plans to support DNS-O-Matic in DumaOS?
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: DDNS Options
Hi bgoodin, I haven't used DDNS myself in that fashion so can't advise unfortunately. Settings is developed by Netgear so I'd advise creating a support ticket in order to request the feature.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1129 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
