× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
DUMA OS issue on dashboard on xr500
Aaremm
Tutor
how do i resolve this error?
Message 1 of 5
Accepted Solutions
Aaremm
Tutor
Re: DUMA OS issue on dashboard on xr500
Hi Netduma_Alex,
I followed your instructions and presto, problem has been resolved.
Thanks for your advice, it was very appreciated.
Aaremm.
Message 4 of 5
All Replies
Aaremm
Tutor
The dashboard has a single pane that has nothing in it except that error and a continuously turning progress circle? I cannot get rid of this pane on the dashboard. I would like to replace it with a PING Time pane?
Message 2 of 5
Netduma_Alex
NetDuma Partner
If you go through the various DumaOS sections, every window has a little Pin icon in the top right. When the pin is filled in white, it's pinned to the dashboard. Could you go through every page of DumaOS (everything except Settings) and check for windows that are pinned? If any are pinned, unpin them. Hopefully whatever pin has glitched will be cleared.
You could also press F12 in Chrome to inspect the Dashboard and see if the broken window has a title in the "elements" section.
If worse comes to worst you might need to do a factory reset to clear the Dashboard.
Message 3 of 5
Aaremm
Tutor
Hi Netduma_Alex,
Aaremm.
Message 4 of 5
Netduma_Alex
NetDuma Partner
I'm glad it worked! You're welcome.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2096 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
