× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
DUMA geo filtering issue with BattleEye and Rainbow Six Siege
Beard444
Follower
Does anyone get this message below when launching R6 Siege? I came to the conclusion that it is due to geo-filtering because I do not get the message when I enable fast search in the geo-filtering options.
When I get the error, sometimes I am unable to connect to the servers, but on other times the servers connect fine.
One more thing I notice is the game launches several times and takes longer to reach the main menu on startup.
19:16:08: Starting BattlEye Service...
19:16:08: Updating...
19:16:10: Launching game...
19:16:31: Note: File blocks can be ignored if they don't cause problems with the game.
19:16:31: [INFO] Blocked loading of file: "C:\Program Files\McAfee\MfeAV\AMSIExt.dll".
Message 1 of 2
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: DUMA geo filtering issue with BattleEye and Rainbow Six Siege
Depending on what your settings are it may be being forced to use some other servers other than its preference which could account for the delay, makes sense with fast mode on you don't experience that. When you're unable to connect have a look at the map and check for anything blocked, you may need to add that to your allow list.
Message 2 of 2
All Replies
Netduma-Fraser
NetDuma Partner
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1406 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
