- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Device manager shows PC in offline Tree when it’s actually online.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Device manager shows PC in offline Tree when it’s actually online.
Which browser are you using? Happen with Firefox or Opera?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't have to use chrome. I don't.
Let us know if the other browsers show same issue.
Does this PC have a reserved IP address?
Wired or wireless connected PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you connect the PC directly to the XR router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using any reserved IPs for the switch or PC.
What happens if you power everything off. Then power ON the router, then switch, then PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets remove the switch from the XR for a bit and connect everything up as best as you can.
Wondering if the switch is causing something here...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most switches never communicate with the router and the Internet at run time. So the one and only action one might ever see is the initial boot probably in combination with the DHCP process. After a while, its well possible the switches are becoming invisible. Keep in mind this device manager or attached devices list on the classic Nighthawk router's are not active management systems regularly polling network devices for the presence on the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Schu
- Mark as New
- Bookmark
- Subscribe
- Permalink
@EQJunky wrote:
It’s just weird that it showed my two PCs and the switch all connected to the LAN instead of the PCs connected to the switch.
Here again, to get a proper network picture some more advanced features like Link Layer Discovery Protocol and some combination allowing the communication between the router and the switch(es) would be required. Neither the switch cores on consumer routers (even many SMB routers) nor the Smart Managed Plus/Netgear Pro Gaming switches offer these features. Therefore, the router can't learn what is connected to a local LAN port or on a switch connected to the LAN port. It's all in the same L2 network - so the LAN.
