Reply
Disable 5G Radio on XR500
downindm
How exactly would I go about disabling the 5G radio in my XR500 router?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma_Alex
NetDuma Partner
Re: Disable 5G Radio on XR500
Go to Settings > Setup > Wireless Setup. Disable Smart Connect, and then you should be able to disable the 5GHz network.
Message 2 of 2
Discussion stats
  • 1 reply
  • 942 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
