× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
DoS Attack
MRowe
Guide
DoS Attack
Hi,
Should I worry about this:
[DoS Attack: SYN/ACK Scan] from source: 185.97.255.42, port 7778, Friday, February 15, 2019 11:03:56
DoS Attack: RST Scan] from source: 31.25.139.237, port 42779, Friday, February 15, 2019 11:02:27
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 11:00:49
[DoS Attack: SYN/ACK Scan] from source: 185.97.255.42, port 7778, Friday, February 15, 2019 10:59:06
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 10:58:46
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 10:56:44
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 10:54:41
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 10:52:38
[DoS Attack: ACK Scan] from source: 31.13.84.2, port 443, Friday, February 15, 2019 10:50:35
Thanks
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 7
Accepted Solutions
Guru
Re: DoS Attack
Use Domaintools.com whois feature to see what those IP addreses are coming from. Contact our ISP about changing the WAN IP address that the modem is passingthru and blocking.
It's just the router reporting what it's detecting and blocking. It's doing it's job.
Message 3 of 7
All Replies
MRowe
Guide
Re: DoS Attack
To Be Continued
[DoS Attack: SYN/ACK Scan] from source: 138.94.200.255, port 39527, Friday, February 15, 2019 11:14:49
[DoS Attack: Ping Sweep] from source: 27.223.78.170, Friday, February 15, 2019 11:12:06
Message 2 of 7
Guru
Re: DoS Attack
Message 3 of 7
MRowe
Guide
Re: DoS Attack
Thanks. I called ISP they said they can't do nothing with this, but you confirmed that at least my router is just doing its job. That's fine. Many thanks again.
Message 4 of 7
Netduma_Jack
NetDuma Partner
Re: DoS Attack
Often DoS attacks are just usual Internet white noise that your router is designed to block. So as your ISP advised, this is just a good sign that the router is doing its job.
Message 5 of 7
MRowe
Guide
Re: DoS Attack
Thanks!
Message 6 of 7
Guru
Re: DoS Attack
Ok, Enjoy. Smiley Wink
Message 7 of 7
Discussion stats
  • 6 replies
  • 23690 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
