- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does Anyone Have the Overall Dimensions of the XR500 With Aerials Fitted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem here is that I need to get a router that sits a very specific place. It absolutely can not go anywhere else. But the XR500 seems very big which may well be a problem. I literally need to cut out a cardboard shape to see if it will go!! So I need to know the width and depth exactly. I think the specs give the measurements without the aerials so I need the measurements WITH the aerials! Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does Anyone Have the Overall Dimensions of the XR500 With Aerials Fitted?
Actually you know I just checked the exact dimensions and it's just too big. It could have been wall mounted but unfortunately that's not possible with the XR500. Shame. I guess that means I just can't buy one! Sorry Netgear but I am a bit limited on space.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
