bacin87
Oct 20, 2018Tutor
Does Model: XR700 support 802.11ac wave2 2x2 160 MHz so I can get the 1.73 Gbps wifi support?
Does Model: XR700 support 802.11ac wave2 2x2 160 MHz so I can get the 1.73 Gbps wifi support? I have a 1 gb sync fiber connection and I replaced the WiFi cards in our laptops to Killer™ Wireless-AC 1550 802.11ac wave2 2x2 160 MHz 1.73 Gbps chips and I want to monopolize on it if I can.
- Netduma_JackNetDuma Partner
I recommend you contact the official Nighthawk Pro Gaming account at https://twitter.com/NETGEARgaming
The XR700 has the Qualcomm QCA9984 chipset and should support 802.11ac wave2 2x2 160 MHz
https://www.qualcomm.com/products/qca9984- schumakuGuru - Experienced User
The XR700 and the R9000 share the same basic platform, radio drivers, and radio firmware. Earlier this year there was a limitation on HT160 being workable on 3x3 only, but not on 2x2 (implemented on Intel AC9260, Intel AC9560, or Killer STA). Altsai please provide the details of the current status.
- AltsaiNETGEAR Expert
Yes, XR700 supports wave2 (160MHz).
