× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Duma OS 3.0 Netgear XR700
xfalax
Tutor
Hello everyone, I have been lucky enough to test the Duma OS beta on a Netgear device and I would like to know if I could enter the Beta for my XR700?
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Duma OS 3.0 Netgear XR700
If you just signed up using the XR500 serial number then I would recommend you sign up again with a different email and your XR700 serial number so you can test that when it is available. It isn't available at the moment but we're working hard to test it and make it available for people to try.
Message 2 of 3
xfalax
Tutor
I registered my XR700 and email the same day it was announced. I know there are still things to improve on version 3.0 but I think I will use the XR700 as the main one since the XR500 and XR ... are not as fast as the 700.
Hope to hear from the beta on XR700 soon because you really did a good job with version 3.0.
Regards.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1042 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
