- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DumaOS not loaded yet!
- Mark as New
- Bookmark
- Subscribe
- Permalink
For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message.
Any idea whats going on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DumaOS not loaded yet!
I did a reset, I get the same issue when I try to login. I had this router running for about a year with no issues. All the sudden today I got this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This happens after login. I am unable to go to any pages. I am on the latest firmware. Did a factory reset and there was no updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have the same problem today. The router works correctly but it's impossible to log in. I have try a downgrade but the pb stay the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem.
We used this workaround:
1. http://routerlogin.net/adv_index.htm
2.Administration -> Firmware Update
3. http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
4. Unpack the .zip file
5. Browse to Image file
6. Upload
This got our XR500s working for now. I hope this helps and I hope this issue gets a permanent solution soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here. Firmware updated two days ago after purchase. Ran fine until this afternoon and now I cant login. There were no changes between working and non working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Dr_Evil_Genius wrote:I'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem.
6. Upload
Thanks, the problem was solved. I stop the auto update to keep this Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
when using http://httprouterlogin.net/adv index.htm
my browser or my XR500 was locked to the DumaOS. I had go
old school typed in its IP address.
So if anyone else has that problem just type or copy and paste
or
http://192.168.1.1/adv_index.htm
Thank you to @Dr_Evil_Genius for thinking of a workaround.
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://routerlogin.net/adv index.htm (correct)
sorry, I was typing either to fast or thinking to fast..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here. Been scratching my head all day about this, but I'm about to downgrade the firmware myself to resolve the issue as it seems this is a fix according thos this forumn and a few others I checked out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi - it should now be fixed actually, so instead of downgrading could you try rebooting your router instead (i.e. turn it off and then back on again). Please let us know if that fixes your problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry didn't read the post above me. Restarting router now to try and see if it's all fixed before I downgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have returned from a business trip to this issue, reboot of router does not fix the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue.
XR500 with firmware version: V2.3.2.56 running from year without any issue.
Then yesterday 2019 Dec 17 DUMAOS FAILED TO BE LOADED.
Resolved using
3.Router Auto Firmware Update -> I Disagree
Hope there is no issue with DUMAS Web service as a lot log available like :
[DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Wednesday, December 18, 2019 11:59:55 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 reboots later and i can now login properly. However now none of the R-Apps will load.
Regardless of being able to log in something is certainly not happy...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would reccomend downloading this firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Then go to http://routerlogin.net/adv_index.htm
Go to administration, firmware update, and upload the file you downloaded.
Now you can upgrade back to the current version again.
This was caused by a temporary issue with our servers, apologies.
