- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DumaOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
DumaOS
I am having problems logging into DumaOS. I can login just fine, but a few seconds after logging in, I get this message, "You are no longer connected to your router. If your router is rebooting then keep this page open as it will automatically reconnect to the router's interface when the reboot is complete. Otherwise please check your connection e.g. you are connected to the correct router." I am both connected to the router by WiFi and Ethernet for double safety (to make sure I have a connection). If anyone can tell me what to do, I would gretly appreciate it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DumaOS
I used incognito mode, and it worked, bnut it shows my Xbox as offline, but it's on, and when I test multiplayer connection in my Xbox, it says that my network isn't set up?????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DumaOS
Sounds like the Xbox or the router might need restarting? The cables are definitely plugged in correctly?
