× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Enabling IPv6 breaks HybridVPN
Ch0b0
Whenever I enable IPv6 (Auto Detect) in advanced settings, HybridVPN no longer protects my connection. I'm using NordVPN with an OpenVPN config. It protects fine when I use IPv4 only. I've tried restarting the router and my devices with no luck. I also have a PureVPN account that I tried this with. The same issue occurs.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Enabling IPv6 breaks HybridVPN
Well, not truely a HybridVPN thing ... the real point is thet these hide-my-a** providers suppot only IPv4.
How to avoid an IPv6 Leak with NordVPN?
Sophisticated clients (by the VPN suppliers) might offer a "leak protection"
How to activate IPv6 Leak protection in PureVPN Windows Software
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
Ch0b0
OK that makes sense. I'll have to wait for them to officially support IPv6. Thanks!
Message 3 of 3
Discussion stats
  • 2 replies
  • 1835 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
