× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Error Mac address and Ports
David_Antunes
Hello i have same manufacture bugs with my xr500.
The 1 is my MAC ADDRESS:
2019-04-13.pngOn the back of my router the mac end with :78 on my windows is the same
The 2 is my ports i have active port 4  and the led is on but in the duma os th uses port 1
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 9
Guru
Re: Error Mac address and Ports
Is the rest of the MAC address the same? I presume it's not and it shouldn't be. The last two characters not not enough to cause a problem. Only if the entire address is the same would it, however it shouldn't be.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 9
schumaku
Guru
Same as ...?
Nothing wrong:
  • The MAC address printed on the label is the one for the LAN interface, so the same .78 you see on the connected clients.
  • The MAC+1 is the Internet/WAN interface MAC address.
Current firmware?
Message 3 of 9
David_Antunes
It is not "same" but some.
My mac address it is not the same printed on the back of my router and the mac address on
duma os software.
Message 4 of 9
David_Antunes
XR500 V2.3.2.40
Message 5 of 9
schumaku
Guru
duma os software.
You said printed and on Windows it shows :78 (this is the LAN interface MAC) while the :79 you see on the Internet screenshot is one higher as expeced - so again, perfectly right.
Message 6 of 9
Netduma_Jack
NetDuma Partner
Was there anything specific you were trying to achieve here that we can help you with?
Message 7 of 9
schumaku
Guru
@Netduma_Jack the OP mentioned "The 2 is my ports i have active port 4  and the led is on but in the duma os th uses port 1" was this addressed by some firmware updates, or do we face early manufacturing units where the numbers/printing/LED don't match?
Message 8 of 9
Netduma_Jack
NetDuma Partner
@schumaku  - thanks for clarifying. If it's an early unit, then the physical labels were incorrect,which may be the cause here.
@David_Antunes - what are you comparing the Device Manager port table to? The LEDs on top of the router, or the number of the port on the back of the router? Are they the same?
Also, how old is your router?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2392 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
